Suspension Tech Have a question about modifying your suspension? Ask it here.
drivers side camber
Old Mar 18, 2007 | 03:19 PM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default drivers side camber
my front drivers side tire has got some negative camber and its driving me nuts. can anyone tell me what could cause this in just the drivers side?
its a 97 4wd
Old Mar 20, 2007 | 07:31 PM
fernandoh's Avatar
fernandoh is an unknown quantity at this point
Default RE: drivers side camber
Lower ball joint maybe is fried. Is a risky condition.
Old Mar 21, 2007 | 01:24 AM
thanks man ill take a look at it tommorow
Old Apr 1, 2007 | 05:36 PM
cat_dr's Avatar
cat_dr is an unknown quantity at this point
I have discovered I am having the same problem. I just replaced both uppers and did an alignment on my garages machine. even with the cam lobe completely turned in I just can't get rid of the neg. camber. I am thinking I just need to replace all ball joints, tie rods and front struts. truck has 200K plus on the chassis so I guess I'll be better off anyways.
Old Apr 2, 2007 | 08:02 PM
where is the cam lobe to adjust?
Old Apr 4, 2007 | 11:07 AM
cat_dr's Avatar
The camber/caster lobes are on the front upper control arm bolt. The bushings are eccentric so if you loosen the nut androtate the bolt head it will turn the camber lobe and move the upper control arm in/out. This is the only adjustment in the front for camber/caster.
Old Jun 23, 2009 | 05:05 PM
mech cb's Avatar
mech cb is on a distinguished road
I think my camber is fine, but my caster is messed up. Will adjusting this bolt fix the problem or do you think I may need new parts?
upmaine
Jul 9, 2012 12:31 PM
Wexinlo
Apr 6, 2011 11:35 PM
gmaltese
Oct 19, 2006 11:30 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
fruccoman
Feb 15, 2006 07:08 PM
