Energy Suspension bushings
Recently installed some Energy Suspension polyurethane sway bar bushings and end links. My first impression is WOW. The first corner I went into I was anticipating the stock roll, but I was surprised. the front body roll is about 1/2 of what it was with stock rubber bushings. well worth the $35. I got the red ones, which are greasable for durability and to keep the squeeks down. If anyone is interested, I would get the black ones, I found out later that they are graphite impregnated and help the anti-squeek which can be a problem with polyurethane.
Nice! I have the poly end links on my Bravada, but haven't had a need to replace the mount bushings. Truck really doesn't lean much anyhow for what it is and the crappy tires it rides on, but I have the rear sway bar and coil over shocks in the back as well. That probably helps a lot.
My stock bar mounts were shot, the rubber was leaning out of the side of one. That was the original reason for replacing them. My next mod is the poly mounts in the rear.
hurleyii
Mar 18, 2014 07:23 AM
krallstar
Jan 7, 2014 07:53 PM
