Suspension Tech Have a question about modifying your suspension? Ask it here.
Energy Suspension bushings
Old May 26, 2006 | 11:03 AM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
Default Energy Suspension bushings
Recently installed some Energy Suspension polyurethane sway bar bushings and end links. My first impression is WOW. The first corner I went into I was anticipating the stock roll, but I was surprised. the front body roll is about 1/2 of what it was with stock rubber bushings. well worth the $35. I got the red ones, which are greasable for durability and to keep the squeeks down. If anyone is interested, I would get the black ones, I found out later that they are graphite impregnated and help the anti-squeek which can be a problem with polyurethane.
Old May 26, 2006 | 11:08 AM
Default RE: Energy Suspension bushings
Nice! I have the poly end links on my Bravada, but haven't had a need to replace the mount bushings. Truck really doesn't lean much anyhow for what it is and the crappy tires it rides on, but I have the rear sway bar and coil over shocks in the back as well. That probably helps a lot.
Old May 26, 2006 | 09:11 PM
My stock bar mounts were shot, the rubber was leaning out of the side of one. That was the original reason for replacing them. My next mod is the poly mounts in the rear.
Old Dec 14, 2006 | 07:12 PM
mallardx's Avatar
mallardx is an unknown quantity at this point
Hey where did you purchase your E.S. bushings? I can't find them for my 99 Blazer on either summit racing or JC Whitney. Thanks!
Old Dec 14, 2006 | 09:27 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
How hard are they to change out and replace? I want to replace the a-arm bushing but that can get hard.
hurleyii
Suspension Tech
Mar 18, 2014 10:21 PM
hurleyii
Mar 18, 2014 07:23 AM
krallstar
Jan 7, 2014 07:53 PM
jayve bass
Jan 31, 2009 11:26 AM
