Suspension Tech Have a question about modifying your suspension? Ask it here.
how to: bottom out the front end on a 4x4
Old Dec 3, 2006 | 06:23 AM
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
Default how to: bottom out the front end on a 4x4
since i couldn't post in the 'how-to' section, i guess i'll just post here. i got this link from another site. i don't know how many of you are interested in lowering a 4x4 blazer, but i'll put it out there for everyone. i should have this done by wed. of this week and i'll let you know how it goes.
Old Dec 11, 2006 | 11:16 PM
djremix's Avatar
djremix is an unknown quantity at this point
Default RE: how to: bottom out the front end on a 4x4
I just dropped my 4X4 3.5"-4" in front and 5" in the back. Used 4" blocks in the back and I ride a set of GABRIEL air shocks so when deflated gives me about 5" in the back. For the front, installed a pair of Nitro-Drop shocks, removed the torsion key bolt and block (for those of you who know how a torsion key works) and I built a plate, welded on the crossmember under the torsion key, and installed a bolt through that new plate...fully adjustable suspension in the front from 1"-6"...
Here's a link to the plate system used on my Blazer, basically same thing as the kit I used but mine is homemade... much easier that flipping your torsion key or replacing with aftermarket key...I basically did mine...for FREE. Just used scrap 3/8" metal plate, welded to crossmember, drilled and tapped, then used a 7/16" Grade 8 bolt to lift the stock torsion key to desired height...
www.proper-designs.com
I am riding 2001 Camaro SS wheels 17X9...I do have all 4 wheels, I just got a blowout on one of the back tires...new tires coming VERY shortly. The front is a bit too low for me right now...I am sitting on the bumpstop (or whatever is left of the 1/2" I didn't cut off).
Check my sounddomain page for pix
blazinloud
Nov 6, 2010 10:08 PM
K5countryboy
Jun 12, 2010 12:15 PM
Jharper
Dec 12, 2007 06:18 PM
2000_BlzrLT
Oct 14, 2007 12:47 PM
skyblazer
Jun 24, 2007 04:54 PM
