Suspension Tech Have a question about modifying your suspension? Ask it here.
popping noise
Old May 18, 2006 | 06:27 PM
Default RE: popping noise
If you can see movement in the tie rod end, replace it! If it were to completely fail, you could end up with little to no steering control.
Replacement of the tie rod end will require an alignment.
Old May 18, 2006 | 07:07 PM
GreenStem's Avatar
GreenStem is an unknown quantity at this point
oh crap, ok will do ASAP most likely this weekend. I'll report back next week with the result, hopefully the noise will be gone.
thanks for the help swartlkk
update;
turns out the outer tie rods were fine, I had a shop look at it and found that both upper ball joints were bad and idler arm.
A day later I took it in to have those replaced and alignment, the loud pop when I turn the wheel all the way is gone BUT I still get ticking noises when braking/accelerating/turning. It's so annoying, could it be my hood hinges?
Old Jun 16, 2006 | 10:15 PM
goblue9976's Avatar
goblue9976 is an unknown quantity at this point
yea, my 2000 Blazer does that too, but only when I turn the wheel full lock either direction...
blaze1002
Dec 23, 2007 03:47 PM
grizz
Dec 11, 2007 06:08 PM
bob the blazer
Suspension Tech
Jun 16, 2006 10:13 PM
RedBlaze
Suspension Tech
19
Nov 14, 2005 12:36 AM
scoot
Jul 12, 2005 10:57 PM
