Suspension Tech Have a question about modifying your suspension? Ask it here.
rear upper shock mounts
Old Apr 30, 2011 | 08:45 PM
zr2dan's Avatar
zr2dan is on a distinguished road
Default rear upper shock mounts
so i went to install my superlift shocks the shocks came off the bottom mount with ease the passenger side upper came apart to so i start workin on the driver side upper and one of the shock mount bolts is seized wont budge its in a place where you cant really heat it any ideas
Old May 1, 2011 | 01:26 AM
rob44_90's Avatar
rob44_90 is on a distinguished road
Can you get anything in there to pound it out with (like an air hammer or punch). They can be extremely hard to get out when the bolts rust in rubber bushings.
Old May 1, 2011 | 11:48 AM
zr2dan's Avatar
i dont know man that upper mount is way up as far as a air hammer it would have to have a long tool in it to reach i dont have anything that long for my air hammer i may just have to bite the bullet and pay shop labor to get them changed
Old Oct 11, 2011 | 10:02 PM
musclemasterflex's Avatar
musclemasterflex is on a distinguished road
Where did you find a replacement mount?
Old Oct 11, 2011 | 10:34 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
get yourself a piece of carbon steel rod about 14 inches long (same size as chisel for air hammer)
have a double edge blade ground, or do it yourself
it will fit up there and you cut it
Old Oct 12, 2011 | 10:10 AM
I called the dealer and they said it was part of a whole cross member GM part # 15017008is that correct?
Old Oct 17, 2011 | 01:50 AM
How do you get the crossmember out and a new one in.. All the rivets are cut, I cant position this any way to get it removed..
Old Nov 13, 2012 | 11:20 AM
Had to cut it. They cut and weld in the new one.
Old Nov 13, 2012 | 01:09 PM
Diaita's Avatar
if its the same as my 96... i pulled the rubber skirts in the rear wheel well and took the air chisel to the Tinnerman u-nuts to break them free. then grabbed what was left of the nut with vise grips and pulled the bolt out.
Old Nov 13, 2012 | 08:43 PM
richphotos's Avatar
Glad I did not have this problem on my first get (94) when I still had it, I had more of a problem getting the ones off of the axle. and they were original shocks, I think if i ran into this, knowing how tight that area was, I would just drive it into a lake.
