Suspension Tech Have a question about modifying your suspension? Ask it here.
shackles, T-bar
Old Dec 31, 2008 | 07:51 PM
DJ 4x4's Avatar
DJ 4x4 is an unknown quantity at this point
Default shackles, T-bar
So i finally got some 2inch lift daystar shackles on my 2000 ZR2 blazer. It was probably one of the harder things i have ever done. Ive seen a lot of posts saying they are having troubles getting out the bottum bolt so heres what i did. The bolt through the leaf spring gets siezed up in the bushing i wrenched on it, hit it with a BFH and got nothing, So iliterally cut the shackle in half and took off the part thats connected to the side where the nuts were (the nuts aren't to bad to get out) then i had the drill out the rubber and pulled the bolt out and replaced the bushing. Its a ZR2 2dr so it was a pain to get to the bolts with the gas tank but i just worked around it. In all it took like 10 hours to do . I still have to crank the T-bars a little to level it out with the back but it doesnt look like it will take much like an inch probably. I think the back was sagging a bit i didnt measure it wish i would have to see how much lift i actually got. From my sig it looks like it sat a lot lower in the back.
Hope this helps somebody. Also ill through some pics online when i get the t bars cranked which should be done by this weekend.
tomborsari
Lifting Tech
Nov 6, 2010 04:34 PM
JS_blazer
Lifting Tech
Dec 27, 2009 07:58 PM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
zippy199
Lifting Tech
Jul 11, 2009 08:04 PM
Cavalier z24
Suspension Tech
Feb 22, 2009 10:08 PM
