squeaking during turn or hit bump
my 98 blazer started to make a squeaking from the driver front wheel last night. sometimes when i turn i hear a loud squeak or if i hit a bump squeak. and when i lift up and down on my fender squeak squeak. possible lower ball joint cause i had my fiance lift on it and i put my hand on the lower balljoint and i feel the grind and squeaking coming from it. and im geting alot of under suspension fixed tomorrow on it do i have time til then to get it fixed or park it til then ps i drive alot for work ruffly 50 to 100 miles a day
General Rule: If you have lube fittings on a ball joint and it is serviced regularly, drive it CAREFULLY straight to the shop when it starts to squeak.
If it is 'lifetime lubed' you have longer.
Ironic, huh.
Ironic, huh.
Markolc
Jun 11, 2012 08:13 PM
pettyfog
Sep 29, 2011 11:36 AM
