Suspension Tech Have a question about modifying your suspension? Ask it here.
squeaking during turn or hit bump
Old Sep 12, 2011 | 06:08 AM
614blazer's Avatar
614blazer is on a distinguished road
Exclamation squeaking during turn or hit bump
my 98 blazer started to make a squeaking from the driver front wheel last night. sometimes when i turn i hear a loud squeak or if i hit a bump squeak. and when i lift up and down on my fender squeak squeak. possible lower ball joint cause i had my fiance lift on it and i put my hand on the lower balljoint and i feel the grind and squeaking coming from it. and im geting alot of under suspension fixed tomorrow on it do i have time til then to get it fixed or park it til then ps i drive alot for work ruffly 50 to 100 miles a day
Old Sep 12, 2011 | 07:12 AM
pettyfog's Avatar
General Rule: If you have lube fittings on a ball joint and it is serviced regularly, drive it CAREFULLY straight to the shop when it starts to squeak.
If it is 'lifetime lubed' you have longer.
Ironic, huh.
Markolc
Jun 11, 2012 08:13 PM
pettyfog
Sep 29, 2011 11:36 AM
xCHIPx
Lowering Tech
Dec 4, 2009 11:43 PM
notmyblazer
Jul 30, 2007 11:54 PM
boomtruck97
Jul 30, 2006 01:35 PM
