Suspension Tech Have a question about modifying your suspension? Ask it here.
ZR2 suspention in a 4 door SLE
Old Jan 24, 2007 | 09:42 PM
jessesjimmy's Avatar
jessesjimmy is an unknown quantity at this point
Default ZR2 suspention in a 4 door SLE
dose anyone know how the ZR2 gets the extra 2 inches of front lift is it the torsion bars or the torsion keys, and do they/can they be swithced with thouse of a reguler 4 door blazer? same with the rear set up dose the ZR2 get its lift from the springs or from shacles, will they work on a 4 door?
Old Jan 25, 2007 | 12:18 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: ZR2 suspention in a 4 door SLE
The whole set up is different. The knuckles, the cv joints, etc. The actual trac width is wider also. I want to do this on mine also, but it is alot of work including different rear axle and spring mounts. Korey.
Old Feb 5, 2007 | 01:01 AM
tippmann243's Avatar
tippmann243 is an unknown quantity at this point
the frame mounting points for the front suspension are also unique to the zr2's
Old Feb 28, 2007 | 10:47 PM
Blaze99's Avatar
Blaze99 is an unknown quantity at this point
so i should stop trying to find a junk ZR2 for parts to use on my 4dr i take it then
Old Mar 3, 2007 | 03:14 PM
Kordog's Avatar
Yeah, that is about it. I have the local body shop on look out for me on a totaled ZR2 so I can rob the suspension. It will be allot of work, and maybe just finding a 2-4" suspension lift would be a better route. Then just get rims with some different offset to make the track width wider. Korey
ken tweedy
Feb 4, 2010 06:20 AM
blazertim20
Lifting Tech
Dec 16, 2009 05:30 AM
boardmeblazer
Oct 17, 2009 10:22 AM
quontush
Suspension Tech
Dec 16, 2005 06:21 PM
dieselfumes
Suspension Tech
Aug 4, 2005 04:51 PM
