1979 Camaro
Old Aug 4, 2009 | 12:33 AM
xCHIPx's Avatar
xCHIPx is on a distinguished road
Default 1979 Camaro
Rims will they fit on blazers?
Ive seen a few around my town that have rims that look really close to the way the 1979 rims look.
Old Aug 4, 2009 | 12:57 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
they have the same bolt pattern so they will bolt up to a 4wd blazer, but youll need spacers to run them on a 2wd blazer
Old Aug 4, 2009 | 01:27 PM
xCHIPx's Avatar
I have a 2wd. Were would you find spacers at and do i need to look for?
I found a guy selling them with tires for 150.
Old Aug 4, 2009 | 03:00 PM
Zeeke98's Avatar
Zeeke98 is on a distinguished road
You do NOT need spacers to run those wheels. The only time you need spacers for Camaro/Firebird wheels is on the 93-02 4th gen wheels. 92-67 wheels will bolt on fine on a 2wd Blazer or S truck with no issues. The only exception being the 16" IROC or GTA wheels which have different offsets front to rear. You can bolt them on but the rears will sit in farther and a small spacer ususally works to get them even with the fronts.
Old Aug 4, 2009 | 03:06 PM
mikeinwi's Avatar
Originally Posted by Zeeke98
You do NOT need spacers to run those wheels. The only time you need spacers for Camaro/Firebird wheels is on the 93-02 4th gen wheels. 92-67 wheels will bolt on fine on a 2wd Blazer or S truck with no issues. The only exception being the 16" IROC or GTA wheels which have different offsets front to rear. You can bolt them on but the rears will sit in farther and thema small spacer ususally works to get even with the fronts.
so like i said youll need spacers .
Old Aug 4, 2009 | 04:49 PM
Zeeke98's Avatar
On 85-90 IROC or GTA wheels you can use a small spacer but do not NEED one. On the 79 Camaro rims he is talking about he needs NOTHING. They have zero offset and most likely a 4" back spacing and are 7 or 8" wide. Hub bore may be the only real concern.
Old Aug 4, 2009 | 05:12 PM
mikeinwi's Avatar
do you have a link to this info? i always thought the camaro rims had the same BS as the 4wd blazers not the 2wd.
Old Aug 4, 2009 | 11:26 PM
xCHIPx's Avatar
The rims im talking about are actully smaller then the stock blazer rims their 14in rims but dont know the width.
Old Aug 5, 2009 | 07:02 PM
Zeeke98's Avatar
I don't have a specific link with the info but it's all over. 93-02 F body rims have 35mm positive offset(+ or - a little depending on wheel width) which is correct for 4x4 S trucks. 92 to 67 Camaros have 0 offset the same as 2wd S trucks. I've had several S trucks over the years as well as several F bodies.
As for the Camaro wheels being 14" they are probably 7" wide. They may not work on 98+ Blazers with the dual piston calipers as I believe the smallest you can go is 15" wheel to clear the brakes.
89stlblazer
Aug 28, 2011 09:17 PM
2003_blazer
Apr 28, 2011 02:29 PM
1homeblown
Mar 2, 2010 09:46 PM
Idriveachevy
Feb 11, 2008 08:10 PM
the fuel
Engine & Internal
Dec 15, 2005 01:25 AM
