1979 Camaro
You do NOT need spacers to run those wheels. The only time you need spacers for Camaro/Firebird wheels is on the 93-02 4th gen wheels. 92-67 wheels will bolt on fine on a 2wd Blazer or S truck with no issues. The only exception being the 16" IROC or GTA wheels which have different offsets front to rear. You can bolt them on but the rears will sit in farther and a small spacer ususally works to get them even with the fronts.
You do NOT need spacers to run those wheels. The only time you need spacers for Camaro/Firebird wheels is on the 93-02 4th gen wheels. 92-67 wheels will bolt on fine on a 2wd Blazer or S truck with no issues. The only exception being the 16" IROC or GTA wheels which have different offsets front to rear. You can bolt them on but the rears will sit in farther and thema small spacer ususally works to get even with the fronts.
On 85-90 IROC or GTA wheels you can use a small spacer but do not NEED one. On the 79 Camaro rims he is talking about he needs NOTHING. They have zero offset and most likely a 4" back spacing and are 7 or 8" wide. Hub bore may be the only real concern.
I don't have a specific link with the info but it's all over. 93-02 F body rims have 35mm positive offset(+ or - a little depending on wheel width) which is correct for 4x4 S trucks. 92 to 67 Camaros have 0 offset the same as 2wd S trucks. I've had several S trucks over the years as well as several F bodies.
As for the Camaro wheels being 14" they are probably 7" wide. They may not work on 98+ Blazers with the dual piston calipers as I believe the smallest you can go is 15" wheel to clear the brakes.
89stlblazer
Aug 28, 2011 09:17 PM
