backspacing for no rubbin' ?
Old Oct 25, 2010 | 07:13 PM
tomborsari's Avatar
tomborsari is on a distinguished road
Default backspacing for no rubbin' ?
so, i recently invested in some 265/75/15 goodyear wrangler tires (31's) for my 1997 s10 4door 4x4 ls blazer. i am curious, though, if i were to invest in some rims with a different backspacing, would that reduce rub on the control arm and such? if so, can anyone help name some sizes? ive been seeing some really nice, really cheap black steel rims online, but i really dont know what im buying here.
help/suggestions?
Old Oct 25, 2010 | 10:13 PM
69chevelle's Avatar
69chevelle is on a distinguished road
yes it would reduce or eliminate rub on the sway bar.
but your wheel could stick out depending on your backspacing which can also affect (increase) rubbing on the fender if clearance is tight
2001 2dr 4x4
the rims I run are 15x7, 4.5" backspacing w/ a 32X11.5(I know a little wide for rim)
I have MINOR rubbing on the frame at full crank(my allignment is out as well which can affect it, once I settle on a ride height I will get it aligned)
hope that somewhat helps
Old Oct 26, 2010 | 04:10 AM
nogi's Avatar
nogi is on a distinguished road
What size lift do you have 69 chevelle?
Old Oct 26, 2010 | 06:36 PM
69chevelle's Avatar
1.5" tb crank 2" shackles and 3" body lift.next I am doing an ad-a-leaf, I like the raked look and haul a lot of weight.
had the front cranked 2" before the BL and it rubbed the inside fender well a hair (turned half way to lock) when lifted with the forklift to the point of back tire comming off the ground. (trimmed the bottem of the inner fender, and the bottem rear of fender then hammered it in to get rid of any jagged edges)
but like I mentioned, I trimmed the back of my front fender before the BL to clear them. stressing that point so someone else doesn't think they can run 32's with a tb crank and no trimming.....
and my bumper cover went MIA so have no idea if that would interfere.
don't have a picture of my truck after the BL but i could take a couple...
I also have not raised my bumpers yet, leaving the front for now as my cover is missing anyway, so making a custom one and the rear I think I have a good, easy way to do that lifting my hitch with it...
Idriveachevy
Tires and Wheels
Nov 1, 2007 08:17 PM
kankoon52
Lifting Tech
Jul 27, 2007 01:10 PM
dirtyjersey
Tires and Wheels
Dec 5, 2006 09:16 PM
jimmyboy
Tires and Wheels
Nov 14, 2006 04:08 PM
SC_Rezahrektion
Suspension Tech
Jan 30, 2006 10:39 PM
