Bart purple stripe wheels
Old Sep 13, 2013 | 01:27 AM
millenniumfalcon's Avatar
millenniumfalcon is on a distinguished road
Default They won't fit
Originally Posted by gringostr
Yea that's pretty much exactly what I'm looking for, but I'm in arizona so it's pretty far away. Plus I'm not sure how well 31'S would fit with no lift of any kind currently installed.
Greetings from Tempe. There are a ton of threads on this, but from everything I have seen, 31 only fits on a 2wd with at least 2" of lift, and even then, trimming might be required. Those purple stripes don't look that great- almost like they are meant for a trailer or something. Spend the extra $12 per wheel and go with at least the Pro Comp in either style. I will be ordering a set of the Pro Comps as soon as the current tires are done. No point in putting well-used tires on new wheels. Also, the stock backspace should be 4.75" for 2wd. Again, from what I've seen on other threads.
Old Sep 13, 2013 | 10:04 AM
gringostr's Avatar
gringostr is on a distinguished road
Ok. I've seen the stock 2wd spacing is 5.75", i just need to measure to find out. I really like the look of wider tires, how well do you think some 30"s on 10" wide rims with 3.75" backspacing should do? I've seen crager and pro conk with those specs.
dve330
Apr 4, 2011 12:50 PM
upblazer95
Jun 25, 2009 10:28 AM
EuroGoldLS
Jun 21, 2007 11:51 AM
Marcin
Apr 23, 2007 10:20 AM
ivannj
Nov 23, 2005 07:54 AM
