camber issue
I put 2wd offset wheels on my 4wd blazer and it makes my camber off. Just wondering if there was a reason for that and if there's any way to fix it other than putting the stock wheels back on cause I really like the look of the offset.
I have 2WD wheels with a front camber of about -2.5° (previous owner of my tires had a camber issue that I'm trying to even out) and it's harder to see with the proper offset 4WD wheels. When I first put them on, I thought I was seeing toe in/out issues as well but it's just because the wheels stick out past the fender and any slight angle is much more apparent than with wheels that sit inside the fenders.
Chances are, you had the camber issue before and it was just harder to see.
(if you cranked your tbars recently, then that's the cause of the camber issue)
Well I have taken it to a shop to get it alligned and they said that they couldn't get it to what its supposed to be. He actually said mine is the only one that he hasn't been able to get strait. I have cranked my tbars and put 31's on it but my buddy has done the same thing but he has the regular offset and his doesn't have a problem. Its only one side of mine that's really bad it looks like its gonna fall off
I think you should look into a body lift. It's a fairly easy way to add 2 inches and it won't affect your alignment, plus it's relatively inexpensive. Usually less than 200 for the kit.
shotnva777
Aug 11, 2011 05:41 AM
