Clear Up Wheel Sizes and Back Spacing
Old Jan 9, 2019 | 06:47 AM
cleburne red's Avatar
Originally Posted by Doubledown
What brand wheels are those the procomp 51s? What did they set you back and where did you end up getting them from. I and been looking around for more procomps like I have on my jeep that look just like those/and every other wagon wheel look -a-like haha.
Yes, pro comp 51s. The set of five came out to just under $300, from summit racing
Old Jan 15, 2019 | 06:24 PM
Doubledown's Avatar
Doubledown is on a distinguished road
So I am reading my lugcentric wheel spacers are the safest after I already picked up a great used set 31x10.5 on some old 5x5.5 ramcharger turbines. I am not finding a hubcentric set, and at 160 per pair of customer adapters I am considering just getting some of those procomps and dismounting/remounting and balancing the tires and selling the rims.
Did you find a hubcentric ring for your procomps to the blazer hub or are you just running the lugs?
Thanks
Old Jan 15, 2019 | 07:15 PM
I don't know about hubcentric, I just ordered them in the 5x4.75" bolt spacing our trucks have, and bolted em on
So, I've been reading about hub vs lug centric, and you have me worried lol
Old Jan 15, 2019 | 08:11 PM
Doubledown's Avatar
The good news is that with such a low backspace setup vs stock you don't have to worry about rubbing on the frame.
The not-so-good news is that with 33x12.5s on 10" wide rims I suspect you'll be hard against the fenders without even turning the wheels, both front and back. And with 3.75" of backspacing, 1.25" spacers, and the aforementioned 10" wide rims you will guaranteed not be able to turn without hitting both the front and back of the fenders. Even with 4" of lift (2" BL and 2" T-bar) I doubt you could turn without hitting the fenders. The outside edge of your rims will be 5" further out than stock (3" wider rim vs stock 7", and 2.5" backspacing when you combine the rims and spacers) plus the extra 2.5ish inches of tire that will be hanging over the lip of the rim vs a stock 235/75/15.
What is the consensus with running aftermarket wheels with different ID bores. Is everyone finding hub rings to adapt or running with just the lugs?
Old Jan 29, 2019 | 05:54 AM
TStoddard's Avatar
TStoddard is on a distinguished road
What is the offset on those wheels? I'm currently.looking for black steel for my 98 4x4 and every time I talk to a rim shop I'm told something different.
Old Jan 29, 2019 | 06:10 AM
Which wheels are you referring to? The ones in the pic I posted have a 4.5" backspacing. Stock backspacing on a 4wd is 6"
rekker94
Tires and Wheels
Apr 27, 2014 06:09 PM
Sturg
Tires and Wheels
May 17, 2010 12:26 PM
94blueknight
Tires and Wheels
15
Jan 12, 2008 04:35 PM
kankoon52
Lifting Tech
Jul 27, 2007 01:10 PM
SkylineGTSt
Tires and Wheels
Jun 4, 2007 11:52 AM
