Did all 2-door Blazers come with reinforcement for swing-away tire carrier?
Old Jun 8, 2020 | 02:01 PM
Xander12's Avatar
Xander12 is on a distinguished road
Default Did all 2-door Blazers come with reinforcement for swing-away tire carrier?
Hey everyone, I have a 98 2-door Blazer. The spare just sits in the trunk laying down. I see lots of things about fitting a carrier to 4-doors and all the things you have to do. Do you need to do this for 2-doors as well? How can I tell if it has the reinforcement? Thanks!
Old Jun 8, 2020 | 03:10 PM
Easiest way would be to remove the plastic mold that cover the rear quarter panel on the inside of the blazer, you should see a small piece tacked to the inner side of the body.
Old Jun 8, 2020 | 07:27 PM
Xander12's Avatar
will do. thanks!
Old Jun 8, 2020 | 07:35 PM
No problem, it should be without 6-8 inches from the lower corner of the window that just above the tail light. If you dont see a piece with nuts welded to it, the you wont have it.
I've also wondered this as I've been in the search of a second vehicle, I've kept an eye on 2 door blazers and wondered if it's as easy as punch, drill, install. The other part I'm wondering is the tail gate, if it has that reinforcement as well...
Old Jun 8, 2020 | 08:20 PM
Here are a couple pics I grabbed from a website that showed the nut on the inside of a 2dr ZR2 that came with the external tire carrier.
rafsbig1
Aug 21, 2014 01:49 PM
chevylover23
Dec 17, 2013 02:03 PM
bigred77
Aug 20, 2009 04:47 PM
