DynaBeads for wheel balancing
Old Mar 23, 2017 | 10:48 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Default DynaBeads for wheel balancing
Stumbled across ceramic beads for internal wheel balancing. Nothing turned up with a forum search. Any one ever try these? Seems like a interest concept.
Old Mar 23, 2017 | 11:31 AM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
I used to work for a company that used them in all of their steer tires, personally I would just stick with traditional balancing.....
Old Mar 23, 2017 | 03:52 PM
Stumpalump's Avatar
Stumpalump is on a distinguished road
Tires get balanced when installed. That balance only changes a little bit after break in so a second rebalance OK. If your trying to solve an imbalance problem later then most likely you have a seperating tire. Beads are best for large tires, slow vehicles or most aftermarket China rims that are not true. That untrue creates a perceived balance problem. If you want bling rims (see fool) then insist the seller show you them spinning true on a tire machine before you mount a tire on them. Garbage house brand rotors from parts stores are also a source of endless balance problems. The beads break up in small tires at interstate speeds and are temporary. You will also have a big problem if fix-a-flat or Slime is already in the tire. Save the beads for trucks and farm implements.
Old Mar 23, 2017 | 09:07 PM
Rusty Nuts's Avatar
It's a trick monster truck guys use to balance those giant tires.
doubride12
Jul 31, 2015 06:07 AM
doubride12
Jul 31, 2015 06:04 AM
Frankiesurf
Aug 3, 2010 05:39 PM
ComputerNerdBD
Tires and Wheels
May 21, 2010 12:14 AM
OuttaControlHPC
Mar 5, 2009 06:07 PM
