good tires?
Old Dec 6, 2008 | 11:28 PM
stevo's Avatar
stevo is an unknown quantity at this point
Default RE: good tires?
ok man
if i go with the 30's, ill have .5inches more of clearence from the sides
theyll be on stock rims with 6 inches of backspacing so i sont think ill have to trim
Old Dec 6, 2008 | 11:36 PM
BlackBeast's Avatar
BlackBeast is an unknown quantity at this point
Check out the dimensions of the 30 you want cause my 31's were 30.7 opposed to the 29's which were 29.5 I believe so, just another thought I didn't know if you've done that or not. Yeah you should be good without trimming I had thought about getting 30x9.5x15's and they were gonna fit with trim so yeah you should be fine if you don't want to trim.
Old Dec 6, 2008 | 11:49 PM
stevo's Avatar
yea, they are really 29.8's but .2 og an ince isnt alot
Old Dec 7, 2008 | 11:42 AM
WolfPack's Avatar
If youre going to get new rims, go with the 30x9.5s. The lower backspacing on the steel rims means you cant run as big of a tire. If you go with 31s, you'll have to cut off a good bit of the wheel well to be able to handle bumps nicely..also if you offroad at all, the whole idea is more articulation...so bigger tire = less articulation.
Rselarep
Dec 11, 2011 07:14 AM
theclothedcreature
Tires and Wheels
24
May 20, 2010 07:07 PM
99s10blazer
Jun 1, 2007 09:13 AM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
lukewb
14
Dec 2, 2006 02:23 AM
