got 22"s on 96 blazer 4x4 that rubs when i turn
Old Mar 28, 2009 | 11:51 PM
hungryace66's Avatar
hungryace66 is on a distinguished road
Default got 22"s on 96 blazer 4x4 that rubs when i turn
I hope someone can help i need to know how to trim or roll the corner of the wheel well so i can turn without rubbing i have 265/35/22 tires please help with any idea's.
Old Mar 29, 2009 | 12:20 AM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
sawzall?`
Old Mar 29, 2009 | 06:26 PM
What is the backspacing on those rims? Has to be out there a bit. Those tires work out to be 10.4" wide and 29.3" outside diameter. Which, given stock or close to stock backspacing, should not cause too much of a problem.
But as Mike has stated... You are likely going to have to cut some things. It really depends on how bad it is rubbing. You could try the 5lb hammer approach and just massage the firewall and inner fender back a bit.
Old Mar 29, 2009 | 09:53 PM
jagblazer01's Avatar
yea ur backspacing sounds like its off......but trimming a bit off the lower part of the fender wheel well shouldnt be a problem
Old Apr 1, 2009 | 12:40 PM
Default 22"s that rub when i turn help?
I have someone to trim the wheel well up but there saying it will put holes and rust out the wheel well i only need 1-2 inches cut on the bottom outside corner of the wheel well my tire is barely hitting the corner of the front fender at the bottom where it meets the wheel well will i be ok
chris015
Jul 27, 2013 03:09 PM
ScottsdaleK5
Sep 16, 2011 03:36 PM
shibbershabber
Feb 22, 2010 10:07 PM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
