Measured effect of upsizing tires
Old Oct 26, 2024 | 09:02 PM
Default Measured effect of upsizing tires
This article from Hagerty has data on changes to mileage etc. when installing larger tires. I thought people might find it interesting.
https://www.hagerty.com/media/drivin...adventure-rig/
Old Oct 26, 2024 | 11:19 PM
AJBert's Avatar
The only problem I have with the article is the rpm difference between sizes. Simple math tells you that a bigger tire will turn less rpm's over a distance. This also means you will have less torque to the road, hence the slower times in the 0-60. I do agree the drive train has to work harder to turn larger tires, thus the less mpg's. To be honest, I wasn't impressed with the article.
My experience going from 31's to 33's was less power to the ground, mpg's suffered, but off road was a non-issue, especially in 4lo. Handling on road suffered quite a bit, from handling to power. I dropped down to 32's and life has been much better. If I ever go up to 33's again, doubtful, I'll regear to 4.11 gears. I'll lose mpg's I'm sure, but the power will be better.
Old Oct 26, 2024 | 11:29 PM
Your points about the reduced torque was why I was ok not going with the 31s and sticking witg the 30 inch tires.
97cherryblazer
Sep 20, 2011 11:22 AM
vrryder
Sep 28, 2009 05:11 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
Hanr3
Tires and Wheels
Nov 28, 2006 02:06 AM
swartlkk
Tires and Wheels
Dec 2, 2005 09:06 PM
