rim help plz
Old Jun 20, 2009 | 06:32 PM
Jfutch101's Avatar
Jfutch101 is on a distinguished road
Default rim help plz
I want to put 31x10.5x15 tires on my 2000 blazer what size rims do i need to buy and whats backspaceing
Old Jun 20, 2009 | 06:34 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
you need atleast 2" of lift first then if you wanna run 31's without trimming youll have to stick to the stock rims or aftermarket rims with the same dimensions. 15x7 6"BS
Old Jun 20, 2009 | 06:44 PM
Jfutch101's Avatar
i have a 2in body lift i need to install
Old Jun 20, 2009 | 06:46 PM
Jfutch101's Avatar
so i dont need to get a wider rim with wider tires?
Old Jun 20, 2009 | 06:51 PM
mikeinwi's Avatar
31x10.50's will fit fine on a 15x7 rim
Old Jun 20, 2009 | 06:55 PM
Jfutch101's Avatar
ok ty
Old Jun 20, 2009 | 06:56 PM
Jfutch101's Avatar
Soft 8 397 Series Wheel
Finish: Black
Size: 15'' x 7''
Bolt Circle: 5 x 4-3/4''
Rear Spacing: 4''
so this good?
Old Jun 20, 2009 | 07:04 PM
mikeinwi's Avatar
use the edit feature in bottom right hand corner of your post...double posting is against forum rules.
if you do not want to trim you need a 15x7 wheel with 6"BS not 4"BS
Old Jun 20, 2009 | 07:28 PM
Jfutch101's Avatar
ok ty now what does backspacing mean
Old Jun 20, 2009 | 07:37 PM
Jfutch101's Avatar
hey they dont make 6in backspacin on these rims
