rim help plz
Old Jun 21, 2009 | 10:15 AM
  #21
Jfutch101's Avatar
Jfutch101 is on a distinguished road
so how much trimming do i need so there is no rub with a 2in body lift with 31 tires and 4in backspacing i looked in the forum and there where no stickys
Old Jun 21, 2009 | 02:32 PM
  #22
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
Old Jun 21, 2009 | 04:28 PM
  #23
Jfutch101's Avatar
ok ty
how do i get more back spacing if the cragar rim doesnt have 6in backspacing
Old Jun 21, 2009 | 08:21 PM
  #24
mikeinwi's Avatar
like i stated earlier, you can use the cragers with a 4.5"BS but youll have to trim or run a 30" tire. if you do not want to trim and run a 31 youll just have to find a rim you like thats 15x7 and 6" of BS or use your stock rims.
Old Jun 21, 2009 | 09:02 PM
  #25
Jfutch101's Avatar
wouldnt 7in wide make the tire over lap alot what if i use 10in wide
Old Jun 21, 2009 | 09:10 PM
  #26
mikeinwi's Avatar
ive said this atleast 3times...a 10.5" wide tire will work without any problems on a 7" wide rim, if you want to get a 10" rim then go ahead but youll have to trim. the recomended rim width for a 10.5" wide tire is 7-9".
Old Jun 21, 2009 | 09:57 PM
  #27
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Let's see if I remember this right, if not someone please correct me but I believe rim width + 4" is the rule so on your 15x7 rim you could run up to an 11" wide tire any larger than that and you would need a wider rim but under that you should be fine so as Mike has said 10.5" wide tire will fit your 15x7 rim with absolutely no issues.
NOW that being said i'd grab a set of 2" shackles and crank the tbars (DO NOT crank them more than 1.5" unless you can afford the time and money to constantly replace balljoints and cv shafts) that in addition to your 2" body lift should negate trimming or at the very least minimize it (again someone correct me if im wrong) second gens arent my typical area gimme a first gen and i can recite all this in my sleep without fear of giving wrong info lol.
Old Jun 21, 2009 | 10:03 PM
  #28
mikeinwi's Avatar
if he runs 31" tires on a rim with stock specs he'll have no rubbing issues with just a 2" bodylift, but if he goes with a wider rim or a rim with less backspacing he'll have to trim or add more lift.
Old Jun 22, 2009 | 01:24 AM
  #29
bandidolenny's Avatar
Hey, that's a pretty cool thread on fender trimming!...lol.
Ok Jfutch101... I think you are trying to go for the wider tire/wheel look. If you wanna go with 10 inch wide wheels then I suggest you get a set with a 5.5" backspacing... any less and you will have a serious rubbing issue in the front when turning and hitting a bump.
Also, you'll probably need more lift...
Old Jun 22, 2009 | 06:20 PM
  #30
Jfutch101's Avatar
right what type of rims are you rocking i was thinking about a cragar soft 8 but they dont make more than 4in back spacing in 15in rims
