rim help plz
Old Jun 20, 2009 | 07:42 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
Originally Posted by mikeinwi
use the edit feature in bottom right hand corner of your post...double posting is against forum rules.
well you could with 4.5"BS if you really want those rims, but then youll have to do some trimming or run a 30" tire instead of a 31"
Old Jun 20, 2009 | 07:49 PM
Jfutch101's Avatar
Jfutch101 is on a distinguished road
im not dbl posting im posting a different response at different times so...
how much will i need to trim?
Old Jun 20, 2009 | 08:00 PM
mikeinwi's Avatar
4. Double posting is not allowed and can result in the deletion of one or both posts. Double posting is defined as posting the same information in two or more separate forums. We understand that some topics might fit into more than one forum. Please try to pick the best one. In addition, please do not post in the same thread back to back (another version of double posting), if you have something more to add, edit your post, don't post twice in a row in a thread.
you must of missed that when you read through the Forum Rules.
as far as trimming goes youll have to trim the rear of the front fender and possibly the front valance.
Old Jun 20, 2009 | 08:17 PM
Jfutch101's Avatar
ok sorry i was not awear
valance? and the trimming is only needed at the bottom correct? meaning bumper and with 10.5 wide tires 7 wide wheels would be to small wouldnt it
Old Jun 20, 2009 | 08:25 PM
mikeinwi's Avatar
yes you should only have to trim the bottom of the fender and valance. if you do a search youll find plenty of threads showing you how and what to trim. like i said earlier a 10.5" wide tire will fit fine on a 7" wide rim.
Old Jun 20, 2009 | 08:28 PM
Jfutch101's Avatar
ok what is valance tho?
Old Jun 20, 2009 | 08:34 PM
mikeinwi's Avatar
its the plastic piece thats connected to the bottom of your front bumper and it holds your front licence plate.
Old Jun 20, 2009 | 08:45 PM
Jfutch101's Avatar
ohhh ok yea i knew i would have to trim that too you you have any pics or any guide lines on how to cut them
Old Jun 20, 2009 | 09:11 PM
mikeinwi's Avatar
if you use the search function youll find what you need.
Old Jun 21, 2009 | 09:01 AM
Jfutch101's Avatar
ok thanks
