Rims for my blazer?
Old 06-17-2009 | 10:19 AM
Frenchyap30's Avatar
Frenchyap30 is on a distinguished road
Default Rims for my blazer?
Hey everyone, i have a 2003 2dr chevy blazer with the zr2 package and i am looking for a good set of rims that arent too expensive that i will be able to put a beefy tire on for off roading. the only lift on the truck is the stock 2in body lift and i dont think im guna lift it anymore so im basically looking for rims that i wont have to modify the truck for
Old 06-17-2009 | 12:05 PM
oktain's Avatar
The factory rims are 15"x7", it's up to you if you want wider/larger.
The bolt-pattern is 5x4.75"
I have a set of winter tires, and all I did was get a factory set from the wrecking yard... they weren't perfect condition though, I had to clean them up and do some sanding/painting along with a couple shots of clear.
Just a set of black steel rims would work too, you'd have to be more specific if you want chrome/nice rims or just any set of rims to throw some mudders on.
Sorry, but I forget what the stock backspacing is... 6" I think... SWARTLKK would know.
Old 06-17-2009 | 02:15 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
the stock backspacing for 4wd is 6".
Frenchyap30- zr2's are 2" taller than regular blazers,but they do not have a body lift installed from factory. its a combination of a different suspension and frame that makes the zr2's taller.
Keystoneguy91
Tires and Wheels
10-27-2012 10:40 PM
Cojack2
Tires and Wheels
14
02-18-2011 06:42 PM
Millertime21
02-19-2007 03:28 AM
batzer
Tires and Wheels
10-13-2006 02:21 AM
Liltruck
Tires and Wheels
10-20-2005 01:38 PM
