tire and rim sizing
Old Mar 25, 2007 | 10:35 PM
mogley99's Avatar
mogley99 is an unknown quantity at this point
Default tire and rim sizing
hey guys i need help, first of all i have a 99 s10 4door blazer, the stock rims i have on now are 15x7s. my question to you guys is can i put 15x8s on without any adjustments or not. if so will the stock tires go on the 8s or will i have to go to a bigger tire? im looking for some black rims(rock crawler style). appreciate any help i can get. thanks
Old Mar 25, 2007 | 10:44 PM
Default RE: tire and rim sizing
Just have to make sure that the backspacing is the same or if anything a 1/2" shorter to center the rim
Old Mar 25, 2007 | 10:52 PM
mogley99's Avatar
i dont know very much about this, so what is the backspacing on what i have now, or how do i get it<
Old Mar 25, 2007 | 11:00 PM
If your truck is a 4wd, then around 6" of backspacing. 2wd is around 4". Backspacing is measured from the back lip of the rim to the hub mounting surface.
You will probably want to get wider tires, but the stock tires probably wouldn't be too bad on an 8" wide rim.
oilers22
Lifting Tech
Feb 10, 2013 09:17 PM
89GMCJames
Tires and Wheels
Dec 2, 2009 04:02 PM
rob44_90
Tires and Wheels
Oct 29, 2009 10:10 AM
mogley99
Tires and Wheels
May 6, 2007 07:12 PM
mogley99
May 3, 2007 05:06 PM
