Tire and wheel dumb question?
Quick question, I want to get the 29x10.5r15 swamper sts tires, the question is, is there a problem with getting 10 inch wide wheels?
RE: Tire and wheel dumb question?
Shouldn't be on the stock wheels. You may hit the torsion bar or frame at full crank, just dont turn it that far if you do. Besides you shouldn't be at full crank anyway, its rough on the cv axles, especially while wheeling.
ORIGINAL: Hanr3
But will the 10.5in wide tires be alright on a 10in wide wheel.
I heard you can go up to 4inches wider than the rim itself... So if you have a 7in rim you should be able to put an 11in tire on. Correct me if I wrong.
