Wheel Expert Needed
Old May 16, 2011 | 12:37 PM
87vert's Avatar
87vert is on a distinguished road
Default Wheel Expert Needed
Hello. I'm new to the forum and need some wheel fitment help. I inherited a 2002 4wd Jimmy and want to upgrade the stock wheels.
I found a set of replica 2010 Camaro SS wheels with a 5 x 120.65 bolt pattern, 40mm offset and a 67.1mm center hub diameter.
20x9 2010 Camaro SS Wheels Rims Black Machine Face on eBay.ca (item 270588097462 end time 28-May-11 12:09:54 EDT)
The bolt pattern and offset seem to work for my 4wd. My question is will I need to to change the studs or anything else to make these wheels fit correctly?
Any help or direction would be greatly appeciated.
Bryan L.
Old May 16, 2011 | 03:13 PM
DySfUnCtIoNaL's Avatar
DySfUnCtIoNaL is on a distinguished road
Nope, should bolt up without a problem.
Old May 16, 2011 | 10:03 PM
87vert's Avatar
Thanks. Found out that the 2010 Camaro wheel hub is 3.2mm smaller than the Jimmy hub.
My only concern left is will the smaller center hub bore on these replica wheels be an issue?
Old May 16, 2011 | 10:17 PM
mdehoogh's Avatar
Hmmmm... I thought the new 5th gen Camaros were 5x120.0mm bolt pattern. I would make sure they are indeed 5x120.65 before ordering. It's possible they replicated them with the bolt pattern necessary for older Camaros
However, if the hub is smaller on the wheels, then they won't fit on your truck. You could possibly add some sort of spacer though. I've seen some 1/4" or 3/8" spacers at auto parts stores that should push the wheel just far enough away from the hub so that the hub diameter is a non-issue. You may need to get longer studs if you go with a thinner spacer like that
Old May 16, 2011 | 10:47 PM
87vert's Avatar
That's what I was afraid of. Spacers are a cheaper option however do you think a machine shop could open up the wheel hub enough to clear?
wallacereid
Jan 9, 2012 12:34 PM
dunontme
Dec 29, 2009 10:39 PM
meatchief
Apr 8, 2009 07:04 PM
86S10
13
Mar 14, 2008 06:53 PM
mortalum620
Aug 15, 2006 10:44 AM
