Would these wheels fit the blaze?
Old Nov 9, 2011 | 03:02 PM
TripleBlackBlazer's Avatar
If you have $100 to spare, I'd buy them anyway. I know BlazinJason in Canada has been looking for a cheap set. If they're close to you maybe you could work something out with him?
I've seen them painted black before on a blue 4 door Blazer. Looked pretty sharp. I'll see if I can find the pic.
265/55/17 would be pretty close to stock tire size in a 17" tire.
Old Nov 9, 2011 | 04:21 PM
tibby's Avatar
Default .
I ended up getting them. That is one wide wheel lol. But I ended up settling on $90. So my $90 bought the 4 maro wheels. I'll post up a pic in the general discussion thread. I'm happy now lol. Hopefully I can get them powdercoated or painted black around middle of December. We'll see.
Old Nov 9, 2011 | 07:43 PM
Blazin_Jason's Avatar
If you decide not to use them, and want to pass them on, holla!!!
Old Aug 13, 2012 | 10:58 AM
El_Beautor's Avatar
Tibby, I just picked up a set of those Camaro rims this weekend too! I was considering painting the insides glossy black and keeping the face the satin silver. I'm probably going to grab a set of used 265/70/17's off Kijiji for now since money's a bit tight. I may have to trim a bit to squeeze them in, but I clear my 31x10.5's fine. The BFG AT's i have on now seem to be a taller 31 so hopefully it doesn't take too much.
Trippleblack, did you have any issues with these rims having more than 6" backspacing? If I'm measuring right they have closer to 7" backspacing.
Old Aug 13, 2012 | 05:32 PM
I did have to trim and I do rub frame at full lock. I still have a set of ZR2 t-bars waiting to go in from forever ago and I think that will solve some of the frame rub. If not I may put a 1-1.25" spacer up front.
Old Aug 13, 2012 | 05:49 PM
El_Beautor's Avatar
I'm currently running 1.25" spacers in the front, and have modified the back of the front fender, so maybe I'll get away with it. We'll see what tires's I'm able to find and afford. Fingers crossed!
Tibby: Have you picked out tires yet? Chances are I'm just going to end up with some basic factory take-offs unless I get really lucky. I'm hoping since 265/70/17 is such a common size I might get lucky and find a good deal.
Old Aug 13, 2012 | 05:56 PM
IIRC, tibby never ran the rims because he rubbed sway bar and didn't want to chance making a hard turn and flipping. At least that's what I think he said.
Old Aug 13, 2012 | 07:06 PM
tibby's Avatar
Default .
Yeah, I was rubbing at 3/4 turn because the rims were so wide with high backspacing. I don't see how you can make them work because of these reasons. I mean a 17x9 with 7 inches of backspacing. Good luck with making them work if you want to give it a go though. The only thing you could try is wheel spacers.
Old Aug 13, 2012 | 07:26 PM
El_Beautor's Avatar
I think I'll be ok. I have 1.25" spacers on the front, and a ZR2 axle out back so I'm already wider than stock. I think I should be ok. I'll post up results in my build thread once I get some tires on them. I wish I could steal the ones of my Durango. I've got 265/70/17 Cooper Zeon LTZ's on there and they are awesome. I absolutely love them.
Old Aug 13, 2012 | 11:40 PM
tibby's Avatar
Default .
Hey, I always liked the wheels. I hope they work out for ya because I haven't seen another blazer able to get them to work besides triple. They look extra schmexy powercoated black. I'll definitely check out your build as I'm curious to see how they look and if they will work.
