Would these wheels fit the blaze?
Old Aug 13, 2012 | 11:53 PM
  #21
TripleBlackBlazer's Avatar
New-to-me Camaro SS Rims - S-10 Forum
Originally Posted by lambert170
They bolted straight up. I do have the spacers in the back to even it out with the front though.
^Which makes me think the ZR2 t-bars will go a long way to stop the rubbing on the frame...
Old Aug 14, 2012 | 07:12 AM
  #22
Jamaroon's Avatar
The extra width of the ZR2 would be what would stop it from rubbing the frame. Put 2" spacers on and you'd be the same as a ZR2.
The only way I can see the tbars helping is the stiffer spring rate would take more for the suspension to compress, but that still won't stop it from rubbing the frame.
Old Aug 14, 2012 | 06:01 PM
  #23
While I agree with the width part of your explanation, don't you think the added height from the t-bars would prevent some of this? You're essentially pushing the frame up and the suspension down with the ZR2 t-bars, no?
Old Aug 14, 2012 | 08:39 PM
  #24
Jamaroon's Avatar
There's nothing extra gained by the ZR2 bars over your bars. Cranking your bars or cranking the ZR2 bars will give the same result for height. You can try cranking yours as is to see how much it will help. I think you will still rub even with them cranked.
I also don't know if you offroad much, but you would still rub if the front is compressed while turning. If you want to stop the frame rubbing, the best option would be to sacrifice some turning radius and build up the steering stops.
Old Aug 14, 2012 | 11:50 PM
  #25
El_Beautor's Avatar
TripleBlack, I think the primary thing you'll gain with the ZR2 bars is it'll stiffen up things, and if your factory bars are sagging right now, it will possibly give you the ability to crank them up some more, as long as you don't put too much stress on your CV's.
I do think your best bet might be to consider a quality set of spacers. I'll try to post up what I find with my setup and hopefully I might find some information that can help.
I've posted pictures over on my build thread here. I found what I think was a good deal on a set of 265/70/17 Nitto Terra Grapplers. They have enough tread to get me through the season, and only cost me $50.
Old Aug 15, 2012 | 05:45 PM
  #26
They're going to look great on your rig! I have spacers but I wanted to put the t-bars in first to see how it changed. Looking forward to seeing what your setup will be.
95jimmy_slt
Tires and Wheels
Mar 11, 2013 03:36 PM
a2dadamm
Tires and Wheels
Feb 5, 2012 08:01 PM
xJakeLIKEShisBLAZERx
Tires and Wheels
Sep 10, 2011 12:50 PM
panthersfan101
Tires and Wheels
Jan 17, 2010 12:20 PM
flowmasta
Tires and Wheels
Aug 10, 2006 11:58 AM
