windcreen washer pump fuse
My windscreen washer pump will not work. It works on the bench. I dont believe the pipes are blocked. I am getting now power to the pump plug. I cannot not locate the fuse. The diagram on the fuse box is wrong. Any ideas please, how this system works,
regard jaygjay
regard jaygjay
What are we working on? Year of vehicle would help. If you're getting power to the plug and it works on the bench then you have a bad ground or a bad connection at the plug. The washer should come off your wiper fuse but I'm not sure what year you have.
There should be a small plastic cover that just pulls off at your wiper control (stalk) and you can check to see of you have power to the wiring that goes to the washer pump. I think that your system works like this. You can check voltage right at the wiper switch (stalk as you call it). When you hit the washer switch you should have voltage at the Orange and Pink wires. Orange coming in and Pink going out to your washer pump. All this is controlled by the solid state part of the wioer motor and module.
kaindragoon36
Mar 25, 2006 04:22 PM
