Front Differential Cable Not Staying Attached at Differential End
Old 03-01-2008, 03:01 PM
98BlazerLT4x4's Avatar
98BlazerLT4x4 is an unknown quantity at this point
Default Front Differential Cable Not Staying Attached at Differential End
First post...
I just got a '98 Blazer and the 4 wheel drive did not work. Thanks to these forums I traced the problem to the vacuum switch on the transfer case and I thought I was ready to go now that my actuator is working and the cable is being pulled. However, the front axle still didn't lock up. I found that the cable was not attached at the differential end, and therefore the fork was not being pulled. I pushed it back in but it will not stay in when the cable is pulled by the actuator.
Is the retaining clip available from the dealer? Should I buy a new cable and try that out?
Thanks for any suggestions.
Old 03-04-2008, 06:00 PM
Default RE: Front Differential Cable Not Staying Attached at Differential End
I replaced just the clip that hold the cable it works fine now. The clip was $9 from GM lol.
Squad-6
04-22-2013 02:19 PM
kickme005
09-06-2010 06:03 PM
kyle123
04-04-2010 02:27 PM
swoop
02-02-2010 11:04 PM
JediKnight2
07-04-2008 05:32 PM
Quick Reply: Front Differential Cable Not Staying Attached at Differential End
