shifter cable adjustment
Old 08-11-2011, 09:39 PM
killallblue's Avatar
killallblue is on a distinguished road
Default shifter cable adjustment
so i have my 99 blazer column shifter how do i adjust the cable it is just a tad off from going in park it almost goes in but dosent so it read it in revers i can put it in park under the truck i have had to do it in bad parking lots a few times e brake only holds so much
Old 08-11-2011, 09:49 PM
Type (or copy/paste) "shift+cable+adjustment" into the search feature and you should find the info.
Old 08-11-2011, 09:51 PM
ahh i didnt do the +s earlyer thanks man
Old 08-11-2011, 09:54 PM
Yeah, the + links the words together making it necessary for all 3 to be in a post/thread. If you just put it in with spaces, it will return all posts/threads with those terms individually (many more results). To constrain it more, you can do an exact term by putting quotes around the term using spaces between words. That can artificially restrict the results though.
The 'Search Guidelines' link in my signature runs through the Boolean search options.
matthewp
04-04-2021 09:16 PM
jasedude
11-24-2010 04:03 PM
rbcar1
12-13-2009 10:20 AM
t.lyttle
05-24-2009 01:37 PM
ChrisAttebery
07-03-2007 12:31 PM
Quick Reply: shifter cable adjustment
