volt meter issue
Old 02-25-2008, 04:41 PM
zombiewoof's Avatar
zombiewoof is an unknown quantity at this point
Default volt meter issue
my voltmeter (in dash) will be holding steady at 14 then drop to 12ish then it will go back to 14, I drove most of the way home today and it was sitting on the low end...I tested the battery with the engine off and it was 12ish (my meter scale is small and hard to read exactly) With the engine started its reading 14 (even though the in dash volt meter is reading low)
I started it again and this time it was reading 14 again..The batery terminals are clean and tight and the car runs well....Any Ideas? Thanks in advance of any replies
Old 02-25-2008, 06:51 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
Default RE: volt meter issue
Your volt meter doesn't measure your battery per say...it measures what your alternator is doing..you might want to have the alternator checked out..if it's not effecting any type of power loss...and the battery is staying charged..it might something else draining on the alternator system..such as stereo/air..etc..
dman001948
11-11-2014 12:10 PM
chris015
07-31-2011 12:32 AM
sebringflyer
03-08-2010 08:31 PM
Numba1Sean
10-03-2008 09:42 AM
S10Blazer
07-08-2008 12:32 PM
Quick Reply: volt meter issue
