Lousy Gas Mileage
Lousy Gas Mileage
Ok, here goes: I just recently had the fuel pump and fuel filter replaced in my Blazer, as well as a tune up and an oil change, but my gas mileage has gotten worse. I was told that it may be the fuel pressure regulator. Any suggestions?
Have you tested your fuel pressure?
Have you run any injector cleaner through? A double dose of the 20gal treatment bottles of Chevron Techron Fuel System Treatment Plus may clean up the injectors/poppet-nozzles.
Are there any stored OBD2 trouble codes?
Thanks for the response. I am not sure if the lines were tested and have not run the injector cleaner yet, but will do that tomorrow. And I am not sure about the trouble codes.
