throttle cable adjustment?
Old 05-16-2009, 07:24 PM
t.lyttle's Avatar
t.lyttle is on a distinguished road
Default throttle cable adjustment?
i need to adjust my throttle cable im at about 80% thottle right now when i put it on the floor....any suggestions?
Old 05-16-2009, 08:44 PM
I am not aware of any actual adjustment built into the cable. You could replace the throttle cable or you could try making some slit washers to put over the cable on the pedal end to space the cable. Get some small washers and cut one side with a pair of side cutters. Then squeeze them together so the ends are touching, but twist them slightly. This will give you a slight opening that you can get the cable into which you can bend back to make them stay on.
Old 05-16-2009, 09:23 PM
oisinirish's Avatar
That works fine. i had to do that on my '80 stepside.
Old 05-23-2009, 09:02 PM
t.lyttle's Avatar
thanks guys it worked i have 100% throttle now!!
Old 05-24-2009, 01:37 PM
Good to hear!
natebocek
08-16-2017 10:02 PM
Squad-6
04-22-2013 02:19 PM
redneck44244
05-30-2012 02:30 PM
bret
02-11-2010 05:58 PM
ChrisAttebery
07-03-2007 12:31 PM
Quick Reply: throttle cable adjustment?
