General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Fuel Gauge
Old 10-29-2006, 06:56 PM
jop's Avatar
jop
jop is offline
jop is an unknown quantity at this point
Default Fuel Gauge
I just recently 3 days ago bought my 1st 1999 Blazer 4X4 2 Door. It has of course the 6 Cyl with pushbutton 4 wheel drive.
I noticed that when I got it from the dealership the fuel gauge was jumping all over the place and they kept it 3 days and it was fine yesterday.
Today I got 4 new tires and an alignment done as I went up in size to a beefier larger tire. I went from 235/15 to a 30.5 in size.
I now notice that the fuel gauge is jumping all over the place again does anyone have any suggestions?
They for some reason did have my battery disconnected as the clock had lost its setting.
Old 10-29-2006, 07:33 PM
jagblazer01's Avatar
Default RE: Fuel Gauge
i answered this in ur New Member Area post but most likely its ur fuel sending unit inside ur tank
Old 10-29-2006, 07:35 PM
ORIGINAL: jagblazer01
Exactly why the 'New Member' area is for new member introductions only and all tech questions should be in the tech section.
Old 10-30-2006, 09:35 AM
jop's Avatar
jop
jop is offline
Sorry about the posting in the wrong place in advance.
The fuel sending unit is what they supposedly replaced at the dealership and it was working fine for one day then after the tire installation and alignment it is now all screwed up again.
Ughhhhh
Old 10-30-2006, 04:06 PM
Take it back and have them to fix what they said they fixed.
Changing tires should not require disconnecting the battery, you might check the positive battery terminal if the battery is still original AC/Delco they are known for loose terminals inside the battery...
Old 10-30-2006, 05:20 PM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
Common problem. I vote for the fuel sending unit inside the tank as well.
Old 10-31-2006, 02:51 AM
As Mark (20Blazer00) has already said, if they claim to have replaced the fuel level sending unit, then they should fix it again if it isn't right.
Old 10-31-2006, 03:10 AM
USMaverick101 is an unknown quantity at this point
I agree with them, their fault, their fix
Old 10-31-2006, 08:31 AM
jop's Avatar
jop
jop is offline
Thanks for the replies. Taking it back tomorrow to be looked at and fixed
grayman63
07-17-2013 01:56 PM
JonZRDeuce
02-05-2012 06:38 PM
hoppy26
01-26-2012 02:08 PM
Mulisha
03-24-2008 09:14 PM
Quick Reply: Fuel Gauge
