Center Column Shifter to Center Console Shifter
My truck is a 2000 Chevy Blazer with an automatic trans and has the center column shifter. I want to convert my column shifter to a center console shifter like I have seen on some Chevy Blazers and GMC Jimmies. From what I have seen all it takes is a dash cluster without the PRND display, a center column shell without the cutout for the tree shifter, and a center console with the shifter.
I know that I have to reroute the shifter cable, but after that I can't think of anything else. Am I forgeting anything; like computers that need to be reprogrammed or anything? If anyone has done this what did you have to do?
*bump* i was looking into this too, you have to get a new cable for the shifter i believe, which is no small sum its like 80-90 bucks for a simple cable, and you shouldnt have to get a new cluster as the console shifter, atleast the stock one, comes with the same wiring harness
98 blazer 2wd 2dr console shifter
ok I've been ***** deep in my blazer. so far saw everything out of a 02 xtreme into it. now I just did a dash swap. had to swap out dash harness. 02 used a def harness cluster bcm airbags. got that change.
now for the fun stuff. I got the shifter self taper to the floors in the same spot as befor. my cab harness dose not have the plug for console harness. got the light hook up the the dash dimer. shift cable is longer for the console shifter also u need the arm off the tramission too. dose anyone have a clean cut way to wire this thing in. I got 5 wires that I need too hook up for the parking lock. so not going to zip tie it
Spraying46
12-12-2009 02:31 AM
