4WD push-button to manual conversion
Old 06-25-2010, 09:15 AM
tululilopo's Avatar
tululilopo is on a distinguished road
Crud, I guess that thing goes to the actuator then, I really have no clue where it would go.
  #22
Old 06-26-2010, 01:38 PM
old skool luvr's Avatar
it's been awhile since i messed with a 1st gen 4x4..................but the wires (i think i remember they were 4-flat wires in white? or were the grey ones that went up top?) are for the lighting on the console cover.
you know the one that lights up if you're in 2WD, 4HI or 4 LO.
personally, i wouldn't worry about t though. i had my truck apart many times and it only worked once for a short bit. never worked when i bought it (and it was only 4 years old) and it started & stopped working all on it's own.
  #23
Old 06-26-2010, 05:08 PM
tululilopo's Avatar
There are two wires coming from the display, they are both flat and white, and one contains 4 wires, and the other contains 5. The 5 wire goes down and connects to a position sensor on the shifter lever. In the donor car at the junkyard, the 4 wire just went behind the dash to an unknown location. And with the new manual shifter in, what tells the vacuum actuator to engage? Also, where does the 3-prong vacuum line that's on top of the t-case go?
  #24
Old 06-26-2010, 08:21 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
The three vacuum lines that go to/from the t-case are: 1- is a vent line, 1-Supply line to the engine, and I'm not sure what the other 1 is for. When you shift the manual case, the vacuum goes to the actuator tell it to contract or release.
The "4x4 no worky thread" on here explains this process better than I just did, maybe go look at it.
  #25
Old 06-27-2010, 10:55 AM
that thread you're looking for is found here.
  #26
Old 07-01-2010, 02:01 PM
tululilopo's Avatar
Thanks.
  #27
Old 07-02-2010, 11:52 AM
tululilopo's Avatar
Well, that thread didn't tell me where that wire goes. Does it just go to the TCCM? All I need to know it where that wire goes, and the donor car has developed a bees nest. I cannot get in there. If anybody could pull up a wiring diagram for the manual 4WD system, or trace that wire, it would be much appreciated.
  #28
Old 07-02-2010, 12:04 PM
tululilopo's Avatar
That's all I need is that wire for a complete manual 4WD conversion.
91chevywt
02-21-2011 07:12 PM
bdubs
12-30-2008 02:36 PM
TRZR2
12-28-2008 09:14 PM
Blazerama
12-12-2008 12:22 PM
DOUGHboy79
08-13-2008 04:54 PM
Quick Reply: 4WD push-button to manual conversion
