1993 4.3 vortec Vin "W" question
I have a 1993 blazer w. a vortec 4.3 W motor and from the searches i've done on here for it it sounds like the Spider is acting up so when I take off the plentium if the passenger side is washed an the drivers side is carboned up what does that mean? or if the drivers side is washed an the passenger side is carboned what does that mean?
Thanks alot!
Thanks alot!
What swart said - go to AutoZone or O'Reilly's (whichever you have) and get the Dorman/HELP! fuel pressure regulator for about $45. It'll come with the Torx security bit you'll need to replace it. Also get the upper intake plenum gasket.
Make sure you have a deep 10mm socket and a Torx T-30 bit. You'll need the T-30 to get the Vortec cover off the plenum and the 10mm deep to get the (10, 11 - something like that) nuts off to remove the plenum.
There is a how-to for the CPI here somewhere...
okay so on the same vehicle different question... All of the rest has been replaced
Fuel Pump
Sending unit
Fuel filter
FPR
"nut kit"
and plugs cap rotor wires
Now there is no fuel pressure for it to run it sounds like its trying to but wont run any ideas on what to try next?
Fuel Pump
Sending unit
Fuel filter
FPR
"nut kit"
When you replaced the fuel pump, did you check the wiring harness?
And when you had the plenum off, did you check the wiring harness to the spider?
Both of those are trouble points.
Also, are you sure it is now a fuel issue and not a spark issue?
okay I finally got the balzer home... an checked the filter its on right... an checked the valve for pressure it squirts out an then pulled a plug an the one plug I pulled out is dry
Any other ideas I can try?
93S10TahoeLT
Apr 5, 2013 06:59 PM
2bejustme
Jan 1, 2013 10:08 PM
redskins1
27
Mar 12, 2010 06:04 PM
SlydinClyde
Oct 18, 2009 08:14 PM
