4x4 conversion?
#31
RE: 4x4 conversion?
it being possible that it could be the problem. u ever had a problem with this 4x4 engager?
#32
RE: 4x4 conversion?
The only thing with wires into it in the front diff is the switch which closes when the front diff is engaged. This should not prohibit the transfer case from changing modes. If you wanted to check this out, disconnect the switch and put a jumper wire across the pins in the connector. I do not know where the ceramic comment came from though...
#33
RE: 4x4 conversion?
Anybody in North East PA want to buy a Blazer?
#34
RE: 4x4 conversion?
ORIGINAL: ptg327
blazer206
Lowering Tech
38
01-15-2011 11:19 AM
76BadSign442
02-01-2007 11:12 PM
