'89 4.3 auto trans service
Old Nov 20, 2009 | 03:06 PM
Thrillhouse's Avatar
Thrillhouse is an unknown quantity at this point
Default '89 4.3 auto trans service
My '89 4.3 just hit 150,000 miles and seems to still drive fine, but the transmission occasionally does some strange stuff. At around 38-40mph it will surge a bit when I'm just barely on the throttle. I'm guessing this is just the torque converter locking and unlocking since it still drives just fine if I jump on the gas hard. It also does something similar at very low speeds on really steep hills, if I'm just giving it a little gas to crawl up the hill it'll buck a bit, as if it's trying to shift to second, but then dropping back down to 1st. Giving it a bit more gas holds it in 1st and it acts normally. Are these worrying signs? My old '88 blazer always shifted a lot and seemed to race to overdrive, then downshift whenever I touched the gas, so it seems pretty normal to me.
As far as I know the truck may still have the original fluid in the transmission, I'm only the second owner and the first owner kept pretty complete records and I don't see anything about a transmission fluid replacement. The fluid still smells fine, and it's full at the correct level on the dipstick. Obviously I need to do the change though, and I plan to as soon as we get a dry weekend day here in Washington.
My question is on the gasket for the pan. I'm a decent mechanic and have worked on several different cars without issue, but this is my first time doing a pan drop on an auto. I know I need a gasket for the pan, but my Chilton's manual says to use "a new gasket and sealant". Is this sealant some sort of RTV? Is it pre-applied to the gasket? Do I need to put it on both sides of the gasket?
Old Nov 23, 2009 | 09:04 AM
mr.vls's Avatar
Do not use any sealant on the gasket. I have an 89 S15 Jimmy and have changed the transmission fluid at least half a dozen times in the life of the vehical. Use NAPA/Felpro/OEM gasket and you will be fine with no leaks. I would change the filter as well. When you remove the filter there is an O-Ring seal on the filter tube make sure it comes out with the old filter. Might need a scribe to remove the old seal. The new filter comes with a new O-Ring for the filter tube.
Old Nov 23, 2009 | 03:45 PM
Great, thanks!
dpmeeks
Sep 29, 2013 07:10 AM
LannyL81
Aug 8, 2010 01:01 PM
ziggy123
Jan 19, 2009 06:53 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
v8vairman
Apr 12, 2006 01:43 PM
