'90 S10 Blazer automatic not shifting gears
Old 11-24-2017 | 01:58 AM
luiguiv's Avatar
luiguiv is on a distinguished road
Default '90 S10 Blazer automatic not shifting gears
Hey guys,
I hope you're doing great. I have a 1990 4.3L S10 Blazer, automatic 4x4.
The car was working relatively fine until today. Started the car, drove it for 5 miles and made a stop for a few minutes, just to find out it was not shifting gears any more.
The car stays in 1 gear despite switching overDrive, Drive, 2 or 1. Reverse is working. If i give it more gas it revs pretty quick. It has never had any slips between gears.
Can this be a shift solenoid problem or maybe a blown fuse for the solenoids (i am not sure if this older models had a fuse for this solenoids)? I am affraid the transmission could be dead
I am not experienced with automatic transmissions; had to research and read a lot on this today due to this problem to get a better idea on what to expect when taking it to a repair shop.
Any information or tips you can provide are much appreciated.
Thanks in advance,
Old 12-03-2017 | 05:24 AM
silentjonsays's Avatar
silentjonsays is on a distinguished road
Did you check the fluid?
Old 12-04-2017 | 12:15 PM
abig84's Avatar
if the speedometer isnt working it could be the vehicle speed sensor.
my 93 has some goofy issue where it keeps popping the ign/gau fuse, but when it does that it goes into 2nd gear until the fuse is replaced
fix-it-dad
02-16-2015 07:43 PM
James1965
01-16-2012 12:32 PM
cory.kiel
06-18-2011 12:41 AM
monette999
10-18-2010 01:41 PM
75 blazer
08-13-2010 07:36 AM
