2000 Blazer not shifting to any gears
Old Feb 16, 2015 | 10:05 AM
fix-it-dad's Avatar
fix-it-dad is on a distinguished road
Default 2000 Blazer not shifting to any gears
Blazer has been shifting fine. Parked it last night, it was about 10 below 0, this morning nothing happens when you shift into any gear. I looked under the car and can see that the linkage is moving when the shift lever is moved. I don't know if this is related but I just replaced the rear disc brakes/rotor/calipers etc.... I test drove after the replacement and everything appeared to be OK. I have not checked the fluid level yet as this happened this morning and I needed to take another rig to work. Is there any way this could be caused by the cold?
Old Feb 16, 2015 | 01:47 PM
newguy's Avatar
really doubt the cold did it. One thing that has been posted a lot is the tran filter falling off. That would cause it. But there is a lot of other things possible also
Old Feb 16, 2015 | 06:43 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Get it good and warm to normal operating temp then check fluid first. as has been said if that is ok it is possible the pick up filter and tube may have fallen off in the pan. next after that is shift solenoids and then pump pressure or lack there of.
ssmith0386
Oct 19, 2014 12:47 PM
gdhurst
May 4, 2014 07:36 AM
James1965
Jan 16, 2012 11:32 AM
monette999
Oct 18, 2010 12:41 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
