Blazer wont start...please help
please help..engine cranks but wont fire..
replaced-
plugs
wires
rotor
dis. cap
(engine is getting fuel)
I think its a minor problem..I got it to start up once and heard a whinding(rubbing) sound from the distributor
(All plugs and hoses hoses are clean, and secure)
Can someone please help????????
replaced-
plugs
wires
rotor
dis. cap
One thing I have left to try is the thick gauge ground wire off the battery, that connects into the bottom of the engine is pulled out a little bit ( but feels firm)
If this is the problem of why the Blazer wont start, then a jump-start should fire it right up, right?
Cuz it doesnt
Cuz it doesnt
Have you checked for spark? What is your fuel pressure? Also what make, model, year?
93 s-10 blazer
yes I checked for spark in the #1 plug and got it..
Not exactly what the pressure is, but fuel squirts out pretty fierce when I push the pin..
The ground wire going from the battery to the engine looks pulled out a bit. (still need to fix)
Could this be the reason it will crank but not fire or it would not crank at all?
Also when I did get it to start while changing th plugsit made a steady whinding/rubbing sound(almost like an electric alarm clock), coming from the distributor...then it died..if this might help diagnosing
zblazerz
04-08-2015 12:22 AM
welderman85
01-10-2014 10:06 PM
bommaritomike
11-19-2010 06:56 PM
birdmomma
05-10-2010 03:03 PM
1992S10blazer4.3
01-29-2010 08:35 PM
