The Dave Jimmy Project
Old Jun 27, 2010 | 06:24 PM
  #21
ddaw735's Avatar
ddaw735 is on a distinguished road
Im degreasing the bottom to be see where its coming from but I believe your right about the oil pan gasket..
Old Jun 27, 2010 | 10:01 PM
  #22
ImScrewed92's Avatar
WOW, now that is a white blazer. White bumpers, wheels everything. Never saw one like that. Very cool find!
Oil gasket shouldn't be bad at all to replace. You have any plans for customizing it? Or you leaving it mostly stock?
Old Jun 28, 2010 | 09:55 AM
  #23
ddaw735's Avatar
Well After I fix the oil leak. Im gonna tackle the squeaky suspension. After that Im gonna move on to the body work and paint. (im repainting it white)
Old Jun 28, 2010 | 11:49 AM
  #24
ohsofly's Avatar
Im tackling my squeaky suspension soon too. Im slowly gathering a parts pile till I have everything, then Ill do the whole thing in one weekend.
ball joints, steering linkage, new Tbars and crank em, shocks, sway bar bushings, control arm bushings and endlinks. That should quieten it down. then Ill do the same on the back and replace everything and new springs.
Nice truck man. Thats a good find.
Old Jun 28, 2010 | 02:22 PM
  #25
ddaw735's Avatar
Thanks and I had the same thing in mind too. But Im still debating If i want to mod this truck at all.
Old Jun 28, 2010 | 08:00 PM
  #26
Trip..'s Avatar
Trip.. is on a distinguished road
I have the black intake runners too. I just saw a Bravada same year as mine, but it had the silver unpainted runners? Anyone know why? What is the significance of the black tubes?
Old Jun 29, 2010 | 08:59 PM
  #27
ddaw735's Avatar
Um what?
Old Jul 2, 2010 | 12:17 AM
  #28
Trip..'s Avatar
Look at the picture of your motor. See the black intake? I have them too. Most s10's have unpainted raw aluminum tubes like these.
But ours are black and I'm trying to find out why.
Attached Thumbnails The Dave Jimmy Project-131_0707_06_z-1992_chevy_s_10_blazer-engine.jpg
Old Aug 2, 2010 | 11:34 PM
  #29
ddaw735's Avatar
Update!!!
So I have Been rust hunting and Im trying to get rid of it while learning in the process.
Fist I noticed the passenger front door did have any molding and because of that water was getting in and rusting out the bottom. Luckily I caught this early and I went to the pick and pull for a new (ish) molding.
Now about that door rust. It was quite a bit of rust developing under the paint but the metal was still solid.... My solution? WIRE BRUSH. I got most of it off using a power drill using the brush bit ( i don't own a angle grinder) and then I sprayed a rust converter to allow me to paint over the rust I couldent git rid of. Now normally i would use sand paper but the way the bottom of the door rusted it was to uneven for me to sand.
After I used the rust converter I sprayed bedliner on it to seal it up and hopefully slow the rusting down..
before
after
Now this was an experiment because I have no clue on how to deal wit rust that wont come off without cutting. And I got to test out a rust convetror. And the way I see it its under the door anyway...
Nowwwww On to the rear!
On the rear lower quarter panel. Right above the muffler there was hole about the size of my foot (i kicked it out of anger) that had rusted completly. I have a pal who knows how to weld and between me and him I think we did a decent job on cutting and welding and painting new metal.
Sorry only have the after for this one.
And To the mods can this thread get moved to the builds section? or should I start a new thread to post more progress?
Old Aug 3, 2010 | 08:50 PM
  #30
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
Looks good on stopping that rust on your door, mine are way beyond that, I'm starting to flake and loose pieces from my door. The back section looks great I was wondering what I was looking at before I read your whole post.
ddaw735
Jul 7, 2010 06:57 AM
Biohazed
Mar 24, 2010 05:35 PM
TheBrettster
Mar 19, 2010 06:31 AM
David Reeves
Dec 7, 2009 11:59 PM
