Fuel Gauge pissin me off...
Old Sep 24, 2010 | 05:56 PM
88_s10's Avatar
88_s10 is on a distinguished road
Question Fuel Gauge pissin me off...
I know the story behind fluctuating fuel gauges in GMs. I have a 96 sierra thats all over the map. Just picked up this 88 S10 Blazer, and the gauge only reads between just under 1/2 and around 1/8. Never reads over 1/2. Even then I know its not accurate, because when it was showing an 1/8 tank I filled up for $40. Is this a sign that the sending units going? Loose ground somewhere? Or gauge just buggered? any input would be great.
thanks
Old Sep 24, 2010 | 06:43 PM
mr.vls's Avatar
Unplug the conector by the rear bumber for the fuel gauge. With the key on and engine off the gauge should read full. If not then you either have a faulty Gauge or a path to ground. If it does read full then you most likely have a faulty sending unit.
Old Sep 25, 2010 | 06:15 PM
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
your float could also be stuck
grayman63
Jul 17, 2013 01:56 PM
JonZRDeuce
Feb 5, 2012 06:38 PM
hoppy26
Jan 26, 2012 02:08 PM
Mulisha
Mar 24, 2008 09:14 PM
