Fuel pump Venting ?, 1993 chevy blazer s-10 tahoe lt
Old Jan 4, 2014 | 05:27 PM
makeminelgd's Avatar
makeminelgd is on a distinguished road
Default Fuel pump Venting ?, 1993 chevy blazer s-10 tahoe lt
Thank you for allowing me in this site , Is there any way of telling if my fuel pump is single , double vent atc , prior to removal of tank , (for ordering purposes )
Thanks
makeminelgd
Old Feb 5, 2014 | 10:53 PM
Bernard's Avatar
Bernard is on a distinguished road
is it a 4x4.and a 4 door?? what vin?....
Old Feb 13, 2014 | 02:13 PM
Bernard , It is a Tahoe LT , 4dr 6 cyl 4.3 Vin IGNDT13W8P2176315. i DID INSTALL A NEW FUEL PUMP , AND IT WORKS FINE , NOT SURE OF PRESSURE THOUGH , STILL NO GO . Thanks
Old Feb 18, 2014 | 08:06 AM
Muddigger86's Avatar
Muddigger86 is on a distinguished road
Ok, However we probably need to know what kind of symptoms you are having to help you properly but for now you may can start here. However, You "REALLY" need to check your pressures. At intake it should be around 55-60 psi and hold after turning off ignition. If not then you have to check regulator inside intake or injector leaking by. Lots of stuff it could be but must start with pressure check. I even had the parts store give me the wrong pump once and had to do it twice because of it. They give me a pump for a tbi instead of the cpi that the W in the vin number indicates. The tbi requires a lower psi for the injector. But yours and mine have the W in the vin at the 8th digit which indicates cpi. You can usually rent a pressure gauge at a local parts store to check the pressure the spot to check is on the driver side of the intake where the fuel lines come in at next to the firewall.
Old Feb 19, 2014 | 09:55 AM
Thanks Muddigger , I can not find the pressure valve (schrader) I have purchased a Haynes manuel for my model , it shows location , but Ill be damed if I can find it . Is it possible it could be in a different location ?
Old Feb 19, 2014 | 12:47 PM
richphotos's Avatar
shrader valve is located on the back of the intake plenum on the drivers side, covered with either a black or blue nipple, wont be in any other location. its tucked down there covered usually with the spark plug wires, so its kinda hard to see.
Old Feb 20, 2014 | 10:59 AM
OK richphotos. Off I go to begin the search . I appreciate all the post that are trying to assist me . You folks are superb !
Old Feb 21, 2014 | 12:33 PM
Hi , just a quick note to let you know that I FOUND THE VALVE , it was right where richphotos said , THKS rich . Now , i am just trying to rent a pressure tester , out of all 4 rental firms in this town , there is none avail, cant believe it , anyone know where i can find at a decent price , I dont mind buying , and then I will loan / rent out . LOL .Again Thank you so much richphotos . Am I correct in thinking there should be about 50-55 lbs and hold that , also what would be the next step if there is good pressure ?
wlorton
Feb 17, 2010 09:23 PM
Sisk
Oct 31, 2009 05:43 PM
mad_blazer
Suspension Tech
Oct 11, 2008 05:31 PM
countryguy1713
Jun 16, 2008 06:53 PM
94blueknight
Jan 6, 2008 01:53 PM
