general question
Old 12-20-2006 | 03:23 PM
FImports's Avatar
FImports is an unknown quantity at this point
Default general question
look i found oil on my starter(not good) so i removed my torque comverter dust cover to check for oil,hard to tell so i noticed my oil cooler line was leaking from the block down the torque converter coverand on the floor.is there any way possible that the gasket on block that the oil cooler line connects to is shot,leaking in the torque converter cover on to the starter.is that possible or is the rear main seal.are there any other ways of checking the rear main seal for leaks.and if it is the rear mainis it worth replacing
Old 12-20-2006 | 10:13 PM
Default RE: general question
Again, why do you insist on starting new threads when this clearly pertains to your thread on oil leaks.
LOCKED! Replies should be done here: leak
Or maybe could it be this one: vaule covers
How 'bout this one: oil cooler line
Maybe this one: rear main seal
No... : no oil
All replies will only be done to the thread entitled leak
All of these threads are off-shoots of the 'leak' thread.
98Ltblazer
04-12-2010 12:34 AM
panthersfan101
Tires and Wheels
24
01-30-2010 11:35 AM
cur dog
07-14-2009 08:37 AM
qquake2k
12-30-2007 01:26 AM
WDRacing
Engine & Internal
11-22-2006 12:48 AM
