has any 1 used this stuff before ?
#21
lol i agree
the glass is on with 1 hinge and the hatch hook is holding it
were suppose to get snow tonight
#22
Good lookin' truck ya have there. I had an '89 2 door, ran it just shy of 300,000 and sold it. Bought a '98 with 30,000 and still have it after ten years & 202,000 Probably keep it another 5 years or so then do it again, love those Blazers. No snow here in Michigan yet, but it'll be here soon enough, along with the salt on the roads.
#23
thank you and yea i love it dearly
its got 138k on the dot
#24
I know a few old schoolers who will solder on glass, but like Hook said, if you're not careful...BOOM !!!! I've seen it, big mess......don't feel bad, there's a million blazers/jimmy's with this exact problem, lol.....including my own.....
J
J
#25
alrighty i installed the window hinge
I connected the wires
I have power to the struts accept one plug and that wire gets hot
is that normal ? or do i have a short ? The wire that gets hot is on the passenger side by the body
#26
It will get hot if there's a poor or loose connection, (high resistance). Check resistance with an ohm meter. Unplug both connectors from the glass, one of the connectors should show less than 5 ohms to ground, the other should show battery voltage.
#27
on the driver side the wire coming from the body has 13 volts
the one on the strut going to the glass has 5 volts
passenger side has 13 coming from the window and 1 volt coming from the body
Im so confused
Im so confused
#28
Resistance, not voltage, on the passenger side. Disconnect the wire from the passenger side at the grid. Measure resistance from that wire connector to ground, (not from the grid to ground).
#29
i think the resistance is 70 if im doing it right
Im using a fluke 110 and i only know how to read voltage and ac with it
edit: i downloaded the manual let me check it again from the wire on the passenger side
edit2: the resistance is 67
#30
Turn the dial straight up, to the upside down horse shoe, that is the symbol for ohms. Stick the red probe in the wire, and the black probe to a good clean body ground.
